problem with trail tech bars on V-Force...
Old Aug 8, 2003 | 06:46 PM
BuggyBrian's Avatar
Default problem with trail tech bars on V-Force...
Anyone else have a problem with the brake lever not setting flat? I have everthing shoved up tight and the lever lines up right in the bend of the bars. Any ideas...
Old Aug 9, 2003 | 04:10 AM
upnorthbacon's Avatar
I put Fly motocross bars with a riser on my vforce. I was running into the same problem with the rear brake. I moved the starter/lights housing down under the cross bar on my bars and then I could slide my brake over far enough on the straight part of the bars. I'm guessing your running fat bars that taper out though? If thier the ones I'm thinking of, I've seen someone in here with them on thier vforce but I don't know if they had the same problem?
njrider64
Jul 4, 2017 01:40 AM
DTroyer01
Jul 3, 2015 07:34 AM
wildbill59
Jun 20, 2015 02:26 PM
Nelson
Jun 20, 2015 01:59 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
