Best Jet Kit/ Air Box mod for Predator
Old Aug 9, 2003 | 11:54 AM
truckracer's Avatar
Default Best Jet Kit/ Air Box mod for Predator
Ok, who's running what for the Predator? How about Rath racing's mod? Or Air box removal with a slip-on filter?
I have an Air Force kit, new, in the box. I would not install it after seeing I had to cut a hole DOWN STREAM of my air filter.
Denny
Old Aug 9, 2003 | 12:01 PM
modquad's Avatar
Right now, the best flow is coming from the Hot Seat kit. The slip-on is the low price, easy alternative.
Old Aug 9, 2003 | 12:03 PM
truckracer's Avatar
Do they have a website???
Old Aug 9, 2003 | 12:06 PM
modquad's Avatar
Hotseatperformance.com [img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 9, 2003 | 12:25 PM
ILPRED500's Avatar
The Hot Seat set up works great, but it all but eliminates your airbox. Be careful if you will be riding where you are going to get wet or muddy. I have the Rath kit installed, and it works great, but I have had some minor problems in some wet harescrambles.
Ryan
Old Aug 9, 2003 | 12:29 PM
truckracer's Avatar
Originally posted by: ILPRED500
The Hot Seat set up works great, but it all but eliminates your airbox. Be careful if you will be riding where you are going to get wet or muddy. I have the Rath kit installed, and it works great, but I have had some minor problems in some wet harescrambles.Ryan
What exhaust are you running with the Rath Kit? Any problems getting the jetting dialed in?
Old Aug 9, 2003 | 01:55 PM
Scotts88's Avatar
yeah, i've been looking around too..see whats the best out there. I also ride in some pretty wet stuff..not sure i want to hack up my airbox or cut after the filter as the air force kit does. Does anyone have any better pictures of the rath setup?
Old Aug 9, 2003 | 03:36 PM
SP700RACER's Avatar
Truckracer, The airforce kit makes more power than any kit available. (dyno and drag strip proven). If you don't want to cut the airbox, use the jet kit and carb mods in the airforce kit and use the hot seat airfilter. Or return the A/F kit and use a 50 pilot, cut 5 coils out of the slide spring, and a 170 main jet. Using the Airbox does make more power than the other filters, but the Hot Seat kit does work well.
Old Aug 9, 2003 | 03:47 PM
RuckusRacing's Avatar
Rocky Mountain Atv sells an all aluminum airbox that will allow you to run without an air box lid. It uses a 250r air filter I think. Its made by UM Peformance Products and cost about $190 bucks. If your running in wet conditions it might be the best setup.
Old Aug 9, 2003 | 03:49 PM
Scotts88's Avatar
Ok...SP700, so your saying just to use what filter with the " 50 pilot, cut 5 coils out of the slide spring, and a 170 main jet??
Would this setup work with the stock exhaust as well?
