Having trouble tightening chain
Old Aug 11, 2003 | 12:13 PM
BigJon's Avatar
Default Having trouble tightening chain
I replaced my front sprocket with a 15 and plan to get a 42 but couldnt tighten the chain enough yet.
i broke like 5 screw drivers! loosened to rear bolts and rolled backwards with screwdriver through both holes and nothing.
Any suggestions?
I got my magura hydraulic clutch level installed though, pretty sweet.
I also got my friend to weld a custom bracket for 2 lights from trailtech to go in the place of stock. Sweet!
Old Aug 11, 2003 | 12:38 PM
Hightower's Avatar
there's plenty of travel to take up slack for a 14T even, your carrier must be stuck somehow. its aluminum spinning in steel so its not rusted together, you'll just have to figure it out. loosen up the two pinch bolts quite a bit, and try to gently pry the gap apart, and see what happens.
Old Aug 11, 2003 | 12:45 PM
BigJon's Avatar
Yep tried the bolt loosening and prying apart the rear.
which way do you push it to get it tightened? backwards right?
And what can I use that doesnt break?
Old Aug 11, 2003 | 02:04 PM
SANDMAN430's Avatar
have you sprayed any kind of lube in there top help any? you might try a hardware store for some hardened steel bolts.
Old Aug 11, 2003 | 03:37 PM
ScoobyDFW's Avatar
use the rod that comes in your tool DS kit. jack up the DS to remove the weight off the axle carrier. loosen the 2 carrier bolts all the way. grab the rear wheel with both hands and turn axle & carrier together to tighten chain. it could be slightly stuck, but should brake free.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
Clint Russell
Sep 25, 2015 03:20 PM
