Carb Balancing???
Old Aug 12, 2003 | 01:41 PM
bobbyclobber's Avatar
Default Carb Balancing???
I'm thinking about buying a carb balancing tool but I was wondering if it is really necessary to balance them. Does this give any noticeable gain or is it OK to adjust them by ear and keep the rear carb a little richer. I at 3 , 3.5 turns front and rear but I dont know if they are "balanced". Any insight is appreciated.
Bob
Old Aug 12, 2003 | 03:09 PM
XC800's Avatar
It is always bet to have your carbs sync'd. The motor pulls even this way when both holes are working together. I had a balancer and found that the best and quickest is to have the edge of both slides "dissappear" at the same time. apply the throttle and feel the inside of the intake. When the first slide is flush with the opening, feel the other carb and adjust it's cable length to match the first carb. you are done!. I have checked this method with the balancing tool and it is so close to bang on that you are good to go
Old Aug 12, 2003 | 03:26 PM
Hey XC: the balancing tool I'm talking about is something like the Carbtune, that uses the vacuum and I believe the idle mixture is adjusted to balance both sides. Is this the same tool you are talking about?
Old Aug 13, 2003 | 02:18 PM
XC800's Avatar
It is run from the vacum the motor created on the intake side of the carbs. you attach it to the carb and there is a pea inside the marked chamber. The pea goes up and down as throttle is applied or backed off . The idea is to ajust the slider timing so that the pea is at exactly the same spot in the chamber on both carb. Hence they are sucking air at the same rate. I picked it up from Cycle Works a few years back
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
