Will Grizzly rims fit on a 450 Kodiak??
Old Aug 14, 2003 | 03:49 PM
RED5's Avatar
Default Will Grizzly rims fit on a 450 Kodiak??
The grizzly rims are aluminum right? I can get a set (4) of grizzly rims and stock tires cheap but will they fit on a Kodiak??
Old Aug 16, 2003 | 06:38 PM
Haymaker's Avatar
yes they should
Old Aug 17, 2003 | 12:46 AM
95wolv's Avatar
All 12" Yamha rims will bolt on to every utility (4 x 110 pattern) and most Honda 12" rims will too. The only problem you might run into is the older 600 Grizzlys had a different offset on the back rims, just make sure they look the same as your stock ones. Other than that, it should be no problem.
Old Aug 20, 2003 | 11:31 AM
anyrider00's Avatar
Ya they should fit.
Old Aug 20, 2003 | 11:40 AM
RED5's Avatar
OK now that I know they will/should fit are the grizzly rims better then the stock 450 kodiak rims?? I know they are aluminum but are they really that much better then the stockers?
Before I buy them I would like to know a couple advantages and disadvantages of putting stock grizzly rims on a kodiak.
I know after market rims are they way to go but that might be a future mod.
Old Aug 20, 2003 | 09:05 PM
95wolv's Avatar
Aluminum is way lighter,you will notice a better ride and handling,less unsprung weight on the axles means the shocks control better,and it takes less power to turn the wheels. I'm not saying you will notice a huge power difference,but you will lighten up the drivetrain by quite a bit. hold a steel rim,then an aluminum one, you will be amazed at the weight difference.
Old Aug 20, 2003 | 11:54 PM
KodiakOwner's Avatar
Hey just curious red but what kind of tires are you putting on them? stockers or something else? I just put 25 bearclaws on my stock rims. ( wishing I Put grizzly rims on them now) Im going to put them to the test this weekend in some mud.
Old Aug 21, 2003 | 11:16 AM
RED5's Avatar
Not sure what tires all stick on them, they have the stcok ones on them now but I'm sure I'll stick something else on them, maybe blackwater XT's or holeshots, just kidding. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 2, 2003 | 11:29 PM
woodsy7's Avatar
02/03 grizzly rims are all the same front and back. the offset on the kodiak rims is different from front to back. the 02/03 grizzly rims are the same as the kodiak front rims only.
YankeeRebel
Oct 6, 2015 06:44 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
