Scrambler stalling out
Old Aug 16, 2003 | 08:52 AM
atvnh's Avatar
Default Scrambler stalling out
I just picked up a 99 scrambler 500, the problem I am having is when I shift into reverse the machine will stall out on me. Cant seem to fiqure it out. Any help would be apppreciated, thanks.
Old Aug 16, 2003 | 09:12 AM
CED's Avatar
CED
There is a rev limiter button on the left side of the handle bar.Push it while in reverse and see if it helps any.
Old Aug 16, 2003 | 05:33 PM
BigBadScrambler's Avatar
is your idel too low??
Old Aug 16, 2003 | 05:48 PM
atvnh's Avatar
No the idle is fine, and the reverse over ride button will keep it running when you shift into reverse but if you put it in reverse w/o using the button or release the button with it in reverse the motor will just quit running.
Old Aug 16, 2003 | 05:52 PM
Sounds like your reverse override is the problem. Check for and loose or disconnected wires. You can also disconnect it, but you will need to do some modification to get the 4x4 to work in reverse.
Old Aug 16, 2003 | 11:16 PM
Maddog419's Avatar
You got a short, use a test light and you will find it real quick. Look for breaks in the wire all the way from the over-ride to the box. If you have a meter it will help. Need more help it's coming.
later
Pehter
Oct 3, 2024 11:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
