Running rich in the low rpms
Old Aug 20, 2003 | 10:49 PM
BADBRONCO's Avatar
Default Running rich in the low rpms
I just switched to the gytr jet kit on my Raptor and I also cut the better part of my air bow off, I put in the 22.5 pilots needles on the 3rd grove and th e160 and 165 mains. I runs great after 1/4 throttle but lower that that it pops and sputters and blows black smoke. I was thinking I have my air screws adjusted wrong or The pilots are to big. What do you think?
Old Aug 20, 2003 | 11:05 PM
Crotts's Avatar
Yeah it sounds like a air mixture screw is set to rich. Air mixture screw controls your low end.
Old Aug 20, 2003 | 11:15 PM
BADBRONCO's Avatar
does turning them out richen it or lean it
Old Aug 20, 2003 | 11:20 PM
Crotts's Avatar
Not sure on a raptor, on a warrior turning it out leans it out.
Old Aug 21, 2003 | 01:07 AM
sixsixT's Avatar
Turning them out richens the mixture.
22.5s are stock pilots, 25s come in the kit. Are you sure which ones you used?
If you followed the GYT-R instuctions they are screwed up as far as setting the mixture screws IMO. You should be around 2 3/4 on both with the 25 pilots.
Make sure your choke plunger isn't sticking.
You did put the spacers and washers on the needles, I hope. That's happened before but I won't mention any names.[img]i/expressions/face-icon-small-wink.gif[/img] Just not me.
Your float level may be a bit high also.
Old Aug 21, 2003 | 08:56 AM
BADBRONCO's Avatar
I used the 25 pilots I must have read them wrong sorry, I double checked my needles and they are right, so I will try and readjust my air screws
Frisky2050
Apr 9, 2020 11:19 AM
ranchobob
Jun 30, 2015 07:38 PM
robj
Jun 15, 2015 08:45 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
Chawness
Apr 21, 2000 08:14 AM
