need help wit sprocket
Old Aug 21, 2003 | 11:57 PM
blaster2003kdk's Avatar
Default need help wit sprocket
what size sprocket should i get for the back.i have a 2003 blaster wit razors on the back .and what will the sproket do for me .more speed or slow me down.i wanna be faster
Old Aug 23, 2003 | 12:21 AM
JohnnySplat's Avatar
well how fast do you wanna go and can your engine handle it? if it was stock, i wouldnt do anything to it, the stock gearing can barely pull itself, so to gear it up wouldnt make any difference except at low speeds (youd go faster in lower gears than stock). i have an 03 blaster too and pretty soon im gonna get a trenga full kit thatll give me a total of 40 hp. im gonna change my gearing from stock of 13/40 to 14/38. a stock blaster can go about 57 mph. with my kit and gearing i asked around and im gonna be in the 70-75 mph range. it all depends on your engine. if youve piped it and have a 30mm carb i would say if you want to go a little faster put on a 39 or 38 tooth rear sprocket. leave the front alone til you get more power. the highest gearing ive seen availiable for a blaster is 14/38.
ill let you decide what your bike can handle. but heres the formula -
front sprocket makes a bigger difference in how fast you go and a larger one will make you go faster, a smaller one will make you go slower.
rear sprocket doesnt make as big a difference and a larger on will slow you down and a smaller one will make you go faster.
i would say after you do this you might be in the low 60's, depending on how much you weigh.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
