Bent Frame
Old May 29, 2000 | 11:23 AM
Scotchbonnet's Avatar
My son was riding our Lakota and a tree jumped out and hit the right front tire and wheel, The tree and my son are fine. The tie rod end snapped and upon further inspection the frame where the lower rear A arm pivot mounts was bent pretty bad the right wheel is about 3" back from the left. Is this a repairable problem? Do I need to get a new frame$$$$? Maybe some judicious bending and welding?
Old May 29, 2000 | 11:52 PM
JD250R's Avatar
This happened to me on one of my Mojaves. I turned the quad open it's side, then I got a piece a thick steel stock that I across on the front and rear wheels. Then i took a hydralic jack and a chain. I set the jack on the steel stock and wrapped the chain around the frame and the jack. Then I heated it up a little then jacked the jack until the tube looked striaght with the other. I left the jack on it over night to make sure the tube could form to it's position. Don't cool the metal with water, it will make it weaker. Once the jack has been on it over night, let the jack down and see if the tube moves any. If it does jack it up more then before so the tube is bent out a little. Let it sit like this over night. If it doesn't move take it off and remove the a-arms and weld up the crack. I put a tube between the two tube so it would be stronger. I fish mouthed the tube ends and it looks liked it came like that from the factory.
Old May 30, 2000 | 08:49 AM
Thanks for the help JD, that's about what I figured I would have to do I just didn't know how to go about it.
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
