wolverine autostart wont work
Old Aug 23, 2003 | 12:33 AM
bmwm5ive's Avatar
Default wolverine autostart wont work
i just got a 2002 wolverine like 1 day ago and it ran perfectly then, but now the engnie wont start unless i use the pull chord.
the starter relay mechanism like buzzes or ticks kinda when i hit the button.
i think theres a short somewhere in it.
any ideas?????????
Old Aug 23, 2003 | 12:38 AM
Warrior453's Avatar
its ur battery is dead that just happened to me like a week ago i think u can go to the dealer and have them check ur battery to see if it is good or not. i would trickle charge it first tho and go from there.
D [img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 23, 2003 | 01:24 AM
bmwm5ive's Avatar
i dont think its the battery cause the lights still work
Old Aug 23, 2003 | 02:06 AM
vampirerider's Avatar
well I think there should be a solonoid on the wolv....hmm, i can go look.....on my 2001 it looks like the solonoid is under the left hand rear fender. Look under your seat and follow the red cable till you find it on yours. I would first lightly tap the solonoid with a hammer or screwdriver handle, etc. If that doesnt fix it, you can expose the terminals on each side and jump them with a screwdriver. Of course check the tightness of the connection first. On the wolv there seems to be a junction box under the seat to feed the lights and such and the starter power doesnt go through it.
Old Aug 23, 2003 | 05:39 AM
rammy's Avatar
bmwm5ive,
yeah i too believe its just a low battery because mine done the same exact thing. the deal w/ mine was it had enough power to run the lights, just not enough umph to crank the witch over.
Old Aug 23, 2003 | 12:11 PM
chad400ex's Avatar
Anytime you get a buzz or "ticking" sound when hitting the starter button...your battery is very LOW...almost dead. It has enough juice to power the lights, but not enough to turn the starter motor.
Old Aug 23, 2003 | 12:55 PM
Warrior453's Avatar
My lights also did work i think u can by a battery around 30 bucks at a dealer.
Old Aug 23, 2003 | 01:02 PM
bmwm5ive's Avatar
i just changed the battery and it worked perfect!
thanks
Old Aug 23, 2003 | 01:03 PM
Warrior453's Avatar
no prob
Old Aug 27, 2003 | 11:53 PM
Eceriderjbomb's Avatar
Your light should still work if you dont have a battery doesent the engine run it or somehing
hugemoth
Jul 20, 2020 03:28 AM
Peter_
Jul 18, 2015 07:06 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
