5 fast HP for a raptor?
Old Aug 25, 2003 | 02:31 AM
Ugintel's Avatar
Default 5 fast HP for a raptor?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2428953688
anyone heard of one of these?
Old Aug 25, 2003 | 03:15 AM
RaptorRidrTX's Avatar
I wouldn't do it, a stock raptor stops making power before you even come near the limiter. You are asking to damage the motor if you remove the limiter, and removing it isn't going to make you gain any HP
Old Aug 25, 2003 | 03:42 AM
scrambler123's Avatar
I agree with raptor rider.
Old Aug 25, 2003 | 10:32 AM
warrior007's Avatar
Its just a reverse limiter bypass, hint - it only adds 5mph in reverse. To test it in the forward gears you would have to actually hit the forward limiter in 5th gear, not many raptors can even pull 5th up to the limiter. When and if you get going that fast you will find the same speed. You will also lose the reverse light.
You can do the same for free by grounding the green/white striped wire that comes from the CDI down to the reverse sensor at the sprocket or put a "fancy" $20 switch on the wire to ground and make it exactly like this kit.
Old Aug 25, 2003 | 10:42 AM
BlackWidow's Avatar
Check out raptortranny.com for the scoop on the limiter bypass. If you're going to do it you might as well spend 20 cents rather than 20 dollars!!
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Hack714
Sep 26, 2015 08:11 AM
black_thunder
Sep 22, 2015 07:59 PM
Hack714
Sep 20, 2015 05:54 PM
