220 starting problems
Old Nov 16, 1999 | 07:16 AM
Loyal's Avatar
My Uncle has a 1998 Bayou 220 with starting problems. He does not use it very often, just around his hobby farm. When he tried to start the bike yesterday the engine made two turns and then went “click click”. Suspecting the battery he tried the pullcord, but after several attempts she still would not start. He tried the battery and the same thing . . . two turns and “click click”. Now the battery is on charge.
Anyone have any experience with this problem? If the charged battery does not work he is going to take it into the dealer to get fixed - $$$$$$$.
Loyal
Old Nov 16, 1999 | 08:27 PM
ScottA's Avatar
I have a'98 Bayou 220 and i have never had any starting problems. Or any other problems. It's a great machine.
-Scott, '98 Bayou 220
Old Nov 18, 1999 | 07:07 PM
mojave4's Avatar
He might have flooded it.Pull the plug clean it or put a new one in and try push starting it.If there is nothing else wrong with it the engine should fire.
Old Nov 18, 1999 | 07:49 PM
flyboy24's Avatar
Hey Loyal,
I have a '96 bayou 220 and it had starting problems too. Mine was the "in gear safty switch" located under the seat. It went bad and I had to buy a new one buy it was only about 40$. Wasnt to bad. Hope this helps you.
Ryan
Old Nov 19, 1999 | 10:36 AM
drlaney's Avatar
Loyal,
The only starting problem I've had with my Bayou is a dead battery that I killed as the result of poor maintenance. I added water to it without charging immediately thereafter.
It acted just like what you describe.
Old Dec 2, 1999 | 09:22 PM
250xrider's Avatar
I had the same problem on my Honda, it was just a bad wire. You should try fooling around with the wires going to the starter. You can check it by taking the starter off and test it, if it dosent turn it is probably the bushings
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
