02 700 speedometer not working
Old Aug 30, 2003 | 10:54 PM
Bill35's Avatar
Default 02 700 speedometer not working
Can anyone tell me if theres a fuse for the speedometer on a 02 700.So far this quads been like a rock but the other day I was out riding and looked down to find my speedometer not working.I love riding this thing but Im not much on working on them so any help would be a big help...Thanks
Old Aug 31, 2003 | 01:36 AM
DustinMinnesota's Avatar
Check the wiring first. Polarises have circuit breakers not fuses. If all the wiring is plugged in tightly you have lost a wheel sensor (Hall effect). These are notorious for going bad. Easy to change all that is required is a 3/8 inch socket and a pair of diagonal cutters and 4 wire ties. The sensor is located behind the right front wheel on the 500s and I am sure it is probably located there on the 700. When replacing do not forget to put the small metal cap back on the new one. A easy check is to take the new one and without routing the wires just plug it into your speedometer and spin the wheel the speedo should jump to like 7 MPH or so.
Old Aug 31, 2003 | 11:00 AM
Bill35's Avatar
Thank you Dustin Can you tell me what side it on ....Again many thanks
Old Sep 1, 2003 | 05:53 AM
VeryPicky's Avatar
The speedo on my 02 700 just took a $hit too and it's the second one, with about 200 miles on it. That being said, Dustin is probably on the right track with the wheel sensor. I havn't got time to look at it yet but the service manual says that the sensor is located on the right front wheel ( as your sitting on the machine). I believe it also said that it was attached to the brake caliper.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
