scrambler died today
Old Aug 31, 2003 | 09:52 PM
scrambler420's Avatar
Default scrambler died today
i went out riding today and after a few miles it just dies on me,i had no clue what was going on.i checked my plug and it wasnt fouled and everything seemed to be ok.if i pulled the choke it would start and then die and wouldnt start back up,then a few minutes later it would fire up and bog out and die..lastnight i shut the fuel off for the first time in months,i was thinking that maybe the valve got stuck or something?but then i looked and there was fuel in the filter.
i turned the gas on and off a few times and it started right up and ran fine for the rest of the day..i dont understand what happened,im thinking it wasnt the shut off valve because there was fuel in the filter..anybody have any opinions?thanks
Old Sep 1, 2003 | 12:52 PM
modquad's Avatar
You must've woke the little gremlin that was sleeping in da bottom of your tank...[img]i/expressions/face-icon-small-happy.gif[/img]. Sorry, You probably did just break something free. Do you change your fuel filter at least annually? People that still run the oil injection should know there's a inline filter by the fuel filter for that also.
Old Sep 1, 2003 | 01:22 PM
TrailBlazerguy250's Avatar
you can give your scrambler to me [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 1, 2003 | 01:29 PM
i changed my fuel filter probably about 4 months ago,i didnt know there was one for the oil also?ill have to go check that out..ok trailblazerguy come get it..
Old Sep 1, 2003 | 01:34 PM
Farmr123's Avatar
Sounds like some crud that got worked loose. Hopefully, it dissolved from the gas flowing through.
Old Sep 1, 2003 | 01:53 PM
ok lol ill even give you my trailblazer for it lol
Old Sep 1, 2003 | 01:58 PM
wow i dont think i can pass that deal up,lol
Old Sep 1, 2003 | 03:16 PM
LOL ok then give me a call lol
Old Sep 1, 2003 | 06:04 PM
Sheilakiller's Avatar
you didn't mention much on history so if by chance you have'nt done oil change regularly or even looked at the lower screen on your oil tank[return line] maybe something clogged. When this happins....esspecially with the synthetics, your motor may safely shut down once or twice before any sounds of trouble....then open up for awhile and oil will flow good then......luck runs out, so if it might have cross your mind for a sec....take a minute to check !!!!!!! I took my 2001 500 scram tank right off and apart, found little gunk for the first time in three oil changes and first screen check.... better safe I say. Anyways, this advice comes from a past experiance and later with a chat with a factory mech...beware...takecare....
Old Sep 1, 2003 | 06:13 PM
killer i have the 400 2-stroke,the only oil i have is the injection oil for the gas..
