Transmission Problem
Old Sep 1, 2003 | 12:04 PM
TheQuadSport230's Avatar
Default Transmission Problem
I was wondering if my problem is a big deal. Looks, my 300ex shift well throught all gear. No problem, no slipping, the gear just get in when I release the clutch. The problem appears when I don't release the throttle to shift in a drag. 1 time of of 3, when I shift for my 3rd speed, the gear won't pop in, I will only hears the motor rev for about 1-2 seconds then It will comes in. It's kinda annoying. What could it be?
Old Sep 1, 2003 | 12:59 PM
Hey, I need help pals !
Old Sep 1, 2003 | 01:01 PM
screaminchief's Avatar
it sounds as if your shift Dogs may be bent or rounded a bit.... not exactly cheap but maube if you explained it more
Old Sep 1, 2003 | 01:19 PM
Likes I told you, it's only doing it when I <u>UP</u>Shift from 2nd to 3rd and when I don't release the throttle to shift. The quad just seems to fall on neutral for several seconds, the chain go slack, the engine still rev up (still holding the throttle), then the gear goes in, the chain makes a real big sounds and everything goes on
Old Sep 1, 2003 | 02:51 PM
Please I need to solve this problem ASAP
Old Sep 1, 2003 | 05:42 PM
BUMP! The forum's currently dead anyway......
Old Sep 1, 2003 | 06:05 PM
matt2490's Avatar
umm its labor day weekend. what do you think most people in the atv forum will be doing. i can't ride. my quad is out collecting dust until i fix it
Old Sep 1, 2003 | 07:10 PM
whatwasthat's Avatar
by the way you you describe it, it sounds like your clutch IS slipping when you shift into 3rd
Old Sep 1, 2003 | 11:06 PM
I don't think it's slipping ; it's not engaging at all. BTW, what's going on with you're 250X Matt?
Old Sep 2, 2003 | 05:55 PM
Please...
