Predator Problems
Old Sep 1, 2003 | 11:41 PM
Scramblin2002ho's Avatar
Default Predator Problems
I went mudding with my Predator today...i know i know its a sports quad but cmon lol ok to my problems....the starter button stuck in what do i do about this....and now when i ride i get on it it will bog for a 1/4 throttle struggle a bit then take off like a bat outa hell whas wrong with the girl? thanks guys!
Old Sep 2, 2003 | 12:09 AM
pred500's Avatar
well, i think mud got behind the starter button and dried up just take it apart and clean it off. but i don't know about your throttle problem. i had a prob with my throttle. it wouldn't idle, but it had to do with the etc.
don't worry, i mud mine too. ALL terrain vehicle [img]i/expressions/face-icon-small-happy.gif[/img]
btw where is your town located in il? im in southern
Old Sep 2, 2003 | 01:50 AM
IBlameTheDog's Avatar
Be carefull when taking the starter switch apart there is a little bearing for the detent on the light switch that falls out when you seperate the case. It is not hard to get back in but be aware that it is there. I had the same problem, and yes I admit it I mud bog too???[img]i/expressions/face-icon-small-blush.gif[/img]
Old Sep 2, 2003 | 08:23 PM
SubaruBaja's Avatar
Ok i can help with the starte problem cause i had the same. first take apart the starter, be careful there are 3 springs, 2 berings, and 4 copper horseshoe connectors. clean it all out, and get ether terminal grease or Vasoline, and just put it all over the green button and all the connection points and it should be fine, oh yah sorry about my spelling i'm not too good at it.
Old Sep 2, 2003 | 08:40 PM
Scotts88's Avatar
I had the starter problem as well..dealer gave me a new switch.
Im having another problem now..i can be out riding and the bike will just die. No power, NOTHIN! But after a minute it'll fire back up again! This is with my headlights off too! So anyways..the dealer looked at it and found a grey wire that goes to the CDI, they patched it up and said it was all good..well its still doing it! FFS..back to the dealer i go!
Old Sep 7, 2003 | 08:51 AM
immfwarrior's Avatar
Did you ever figure out what was wrong? I was riding mine in the river and the starter button stuck, noticed it right away and got it freed up then the next sandbar I noticed the headlights were going dim. I was giving this girl a ride because her 4x4 took a crap up river so we left it but anyway she hit my shift lever and it diedand wouldn't start. Trying to jumpstart a 4-wheeler on a sand bar is almost impossiblewithout a towrope but we did it. Once we got it started when ever you pulled in the clutch lever the headlights would dim and it would backfire and want to die. and finally it did
Old Sep 7, 2003 | 12:08 PM
Scotts88's Avatar
Nope..its at the dealer right now. YOur prob seems more like charging. My bike will die if yoru driving it WOT..there is NO power..you cant jump start it..
Old Sep 8, 2003 | 03:59 AM
Birdman7's Avatar
Hey for the throttle prob its sounds like your filter needs clean or you are to rich you are getting too much gas to start and when you get wide open it cleans out and hauls.
1966F100
Jul 24, 2015 02:17 PM
hondarider1234
Jul 21, 2015 11:53 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
