transmission question on blaster
my friends blaster is having a little problem and i told him i would find out whats wrong. what the problem is when he shifts from 4th to 5th it gos into neutral and justs revs. this happeans with a full shift up and he just change the oil in it to see if that was the problem, but could the problem be the oil was bad? or is it something else? any help would be great. thanks
are you sure it's neutral? after it does this does he shift up from "nuetral and hit second gear? ok so if it is nuetral he's hitting then his shift fork could be slipping out of gear. i'm probably not really answering your question but is it only from 4th to 5th?
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
