transmission question on blaster
Old Sep 2, 2003 | 09:00 PM
hotseatperformancefan's Avatar
Default transmission question on blaster
my friends blaster is having a little problem and i told him i would find out whats wrong. what the problem is when he shifts from 4th to 5th it gos into neutral and justs revs. this happeans with a full shift up and he just change the oil in it to see if that was the problem, but could the problem be the oil was bad? or is it something else? any help would be great. thanks
Old Sep 2, 2003 | 10:01 PM
crispy's Avatar
are you sure it's neutral? after it does this does he shift up from "nuetral and hit second gear? ok so if it is nuetral he's hitting then his shift fork could be slipping out of gear. i'm probably not really answering your question but is it only from 4th to 5th?
Old Sep 2, 2003 | 10:06 PM
warrior007's Avatar
yup, sounds like a bent shiftfork to me.
Old Sep 3, 2003 | 06:10 PM
thats what he says only from 4th to 5th it happeans as of now
Old Sep 3, 2003 | 07:04 PM
crispy's Avatar
can he ever get it into 5 and 6th?
Old Sep 4, 2003 | 08:56 PM
no he looses it in all gears he said i was wrong
Old Sep 4, 2003 | 11:23 PM
duckdiaz's Avatar
what yr is the blaster? is it going into 2-3 after nuetral thats a good Q: crispy......
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
austinwhitton
Aug 11, 2015 06:21 PM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
