Warrior Exhaust
Old Sep 6, 2003 | 10:02 AM
HondaMan400EX's Avatar
Default Warrior Exhaust
I have a 2000 Yamaha Warrior and I want to put a new exhaust on it. I was thinking about the FMF Megamax II and the Powerbomb header, would this be a good system for lowend and midrange? I ride trails mostly. Let me know if the system is good for lowend and midrand or any other suggestions on systems for lowend and midrange, but I mostly want to know about the FMF system I mentioned. Also does the FMF Megamax II have the tuneable disk? I know the Meagamax did but I dont know about the Megamax II
Old Sep 6, 2003 | 11:25 AM
chad400ex's Avatar
Yes it does have the tuneable disc end cap. And...yes, it's a good pipe for your Warrior. I had just the slip on Megamax II on a Wolverine (basically same engine) and it made a ton of low and mid range power. I actually had a 4" Supertrapp race exhuast on my 96 Warrior (with 10 discs on the end) and it made so much low end power that I ended up going up one tooth on my front sprocket. Anyway... yes, that pipe/header would be great for your Warrior, and relatively inexpensive compared to some of the others.
Old Sep 6, 2003 | 06:55 PM
Warrior350ripper's Avatar
Pro CirCuit T4- i likez mine
Old Sep 6, 2003 | 09:03 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
hondaman i'm gettign the saem xact xhaust soon.... i got a ? tho does it coem with jets and filter??
Old Sep 6, 2003 | 09:22 PM
chad400ex's Avatar
It won't come with jets and/or an air filter. Those come separate, unless you buy them as a package deal from somewhere. Albaaction.com has good kits for the warrior. They would come with everything you need, and so does Goldenwestcycle.com
Good Luck!!!
Old Sep 6, 2003 | 10:44 PM
Speedy2222's Avatar
alba u have to re-pack and the MBRP i was looking at .. .so ima get 1 of there ful lsys.
Old Sep 6, 2003 | 11:52 PM
JakalWarrior's Avatar
Full system is pointless on a warrior. Look at that header pipe, thats on a 350cc motor! Use some common sense. When you buy headers on a car, you want ones that are bigger and flow better, so if your car comes with a set of headers from the factory, some aftermarket ones arent going to help....
Old Sep 9, 2003 | 03:17 PM
No you need a different head pipe depending on what kind of power you want. If you want more top end, you want a bigger header tha flows air better, but if you want lowend/midrange you want a smalled headpipe that will have back pressure and make lowend/midrange
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
