Warrior Exhaust
I have a 2000 Yamaha Warrior and I want to put a new exhaust on it. I was thinking about the FMF Megamax II and the Powerbomb header, would this be a good system for lowend and midrange? I ride trails mostly. Let me know if the system is good for lowend and midrand or any other suggestions on systems for lowend and midrange, but I mostly want to know about the FMF system I mentioned. Also does the FMF Megamax II have the tuneable disk? I know the Meagamax did but I dont know about the Megamax II
Yes it does have the tuneable disc end cap. And...yes, it's a good pipe for your Warrior. I had just the slip on Megamax II on a Wolverine (basically same engine) and it made a ton of low and mid range power. I actually had a 4" Supertrapp race exhuast on my 96 Warrior (with 10 discs on the end) and it made so much low end power that I ended up going up one tooth on my front sprocket. Anyway... yes, that pipe/header would be great for your Warrior, and relatively inexpensive compared to some of the others.
It won't come with jets and/or an air filter. Those come separate, unless you buy them as a package deal from somewhere. Albaaction.com has good kits for the warrior. They would come with everything you need, and so does Goldenwestcycle.com
Good Luck!!!
Good Luck!!!
Full system is pointless on a warrior. Look at that header pipe, thats on a 350cc motor! Use some common sense. When you buy headers on a car, you want ones that are bigger and flow better, so if your car comes with a set of headers from the factory, some aftermarket ones arent going to help....
No you need a different head pipe depending on what kind of power you want. If you want more top end, you want a bigger header tha flows air better, but if you want lowend/midrange you want a smalled headpipe that will have back pressure and make lowend/midrange
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
