how do you change gearing in a 4x4
Old Sep 7, 2003 | 01:25 PM
TooFastIsBarelyEnough's Avatar
Default how do you change gearing in a 4x4
2wd's just change the sprockets but with a 4wd that needs to have the proper ratio for the 4x to work properly what to do ? I would like to get a little more top end any suggestions?
Old Sep 7, 2003 | 02:32 PM
BONEshock's Avatar
the easiest way is with tires. it can be done with clutch weights as well.
Old Sep 7, 2003 | 02:56 PM
for the 4wd to work correctly my dealer said that I couldn't change the tire size. or sprocket size. unless they were done in synch so the ratio would be the same as now so wit h20% slip in the rear tires the 4wd kicks in any otherr suggestions?
Old Sep 7, 2003 | 03:05 PM
BONEshock's Avatar
i dont think changing the clutch weights would affect your AWD. people do it all the time and never have a problem. I dont think changing your sprocket will afect it either. I changed the front sprocket on my old explorer 250 and I didn't have any problems with the AWD, dunno if i just didn't notice or it really did work ok. tires would be the easiest way to go but are a lot more money and I dont think you get a real big gearing change out of them. I'd try the clutch weights if you know your way around the CVT.
Old Sep 7, 2003 | 07:11 PM
Farmr123's Avatar
Clutch weights won't affect the 4wd.
If you go to bigger tires, get all 4 at once, and to the same ratio: For example, if your fronts are 2 inches smaller than the rears, get the new ones 2 inches smaller. That should keep things close enough to work.
Old Sep 7, 2003 | 07:25 PM
I have clutching already I have a hsp speed kit which includes weights and springs. I would like to get a little more topend.
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
micheleLeigh
Jul 19, 2015 07:32 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
