how about a girdle kit?
Old Sep 7, 2003 | 09:14 PM
TooFastIsBarelyEnough's Avatar
Default how about a girdle kit?
I looked at all the aftermarket dealers and didn't see one anywhere I'm getting a wiseco piston and trail porting and would like to get the girdle kit also can someone help.
Old Sep 7, 2003 | 09:20 PM
FTZLT250r's Avatar
Did you check HPD?
Old Sep 7, 2003 | 09:28 PM
FTZLT250r's Avatar
It's listed under the race mod kit for $50..... I really don't think you need a girdle kit with a trail mod engine. I think HPD will tell you the same, unless you are jumping a lot.
Old Sep 11, 2003 | 09:55 PM
DO YOU NEED A GIRDLE KIT WITH A TRAIL MOD ? I JUMP EVERY CHANCE I GET, NOT LIKE A CRAZY MAN OR ANYTHING 10-20' MAX. BUT I AM GETTING A TRAIL PORT AND WISECO PISTON SOON AND THOUGHT I SHOULD GET THE GIRDLE KIT ALSO BUT I AM NO EXPERT ANY ADVICE ? THANKS BILL
Old Sep 12, 2003 | 02:18 AM
modquad's Avatar
Getting the girdle kit can never hurt. Also, HPD has a weld on re-inforcing plate for the LH rear of the block, both great strengthening ideas.
Old Sep 12, 2003 | 10:13 AM
sportkc's Avatar
AAEN has a girdle kit that works with the stock head. I'm not sure if it will work with a billet head but I would sure use it if it did. When I was a RCR last time he had three trail ported cylinders that had to be welded up ater they broke. Kevin
Old Sep 12, 2003 | 12:25 PM
RickRitter's Avatar
For a Stock head after modifications the Aaen girdle works well , I keep them on the shelf and use them myself .
Old Sep 12, 2003 | 06:05 PM
FTZLT250r's Avatar
HPD has said that the girdle kit is mainly for the high compression engines, and for people that land their jumps with the throttle on. I think that's why HPD didn't develop one for the stock head.
Like ModQuad said, it can't hurt......
Old Sep 14, 2003 | 03:04 PM
scramblered's Avatar
that right,with the 15.5 head on,the engine shake like crazy even at idle,and i have the hardest HPD motor mounts,the best thing i found is the torque plate from arizona bad boyz,it cost 53$ and really does help to maintain the engine in the clutch alignments,a must have.
Old Sep 14, 2003 | 04:35 PM
modquad's Avatar
Gotta agree with that. The torque plate from Dennis (AZ Bad Boyz) when matched up with my super classified polyurethane mount system really holds the modded 400's in place. Just have to bug him for his wheelie bar...cause I don't think I'll have time to fab one up.
SherpaT350
Jan 19, 2007 10:13 PM
thewayout420
Jan 6, 2007 10:34 AM
SherpaT350
Jan 4, 2007 10:34 PM
conig
Dec 14, 2005 12:14 AM
oghma
Apr 19, 2005 07:50 AM
