Stock DS650 HP rating & Recalls
Old Jun 1, 2000 | 10:25 PM
TKeeler's Avatar
What is the stock HP rating of the DS650? I would also like to know all of the recalls that are supposed to be performed on the 650 so I can be sure the dealer does them or checks to see if they need done before I take the machine. Is there a list somewhere of recalls? Thanks.
Old Jun 2, 2000 | 08:36 AM
KawasakiKid's Avatar
In estimate to stock (rear wheel) horsepower, you're looking at 44HP.
In regards to recalls the following are the ones I'm aware of:
-Rear axle lock nut coming loose (improper torque)
-Front ball joint missing locking pin
More than likely, if it's a later production model these problems would have been resolved. You can check them yourself easily. Look at the front A-arm near the wheel, and see if the nut has a locking pin through it. And the axle, just move the DS from side to side via the rear grab bar and see if there is any play in the axle.
I continually check the rear axle, chain tension, etc. on my bike for safe measures.
Any good trail rider or racer will tell you to inspect your bike each time before riding.
Hope this helps!
ReconBayou
Oct 31, 2022 05:37 PM
dannytas
Sep 26, 2017 06:31 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
fredrikrosen
Sep 28, 2015 09:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
