oil light
Old Sep 8, 2003 | 10:17 PM
TrickyP's Avatar
Default oil light
I don't know what is going on I power washed my bike after a day of rideing and when I started it back up the oil light will not go out,,,,any suggestions its brand new its the second time rideing,,,,would water short out the sensor the easily
Old Sep 8, 2003 | 11:23 PM
DSJOBBER's Avatar
Default oil light
Prolly. Light went out on my 03' after a few months. Ditch the light and mount a gauge that way youll never be wondering if you have oil pressure or not. The oil pressure sensor going out seems to be fairly common.
Old Sep 8, 2003 | 11:29 PM
BaJaBoy03's Avatar
Default oil light
Yup...common problems are ....
1. Oil Sender
2.Temp Fan Switch
3.The lights themselves even go out.
I am on my third oil sender and mine quad is only 8 months old.
Old Sep 9, 2003 | 10:16 AM
TrickyP's Avatar
Default oil light
would an auto meter oil pressure gauge work? or where would I be able to get one
Old Sep 9, 2003 | 10:21 AM
ironrod's Avatar
Default oil light
Sand45 ran into this - It would seem that if you power wash your quad, the sensor for the light gets ruined. Get yourself a new sensor and don't power wash near it. It's on the right hand side and two wires plug into it right near the fuel shut off valve.
Old Sep 9, 2003 | 12:06 PM
DuneMe's Avatar
Default oil light
The connection near the gas **** is the temperature sensor.
I believe the connection under the carb and in the cases is the oil pressure sensor
Both of these are tied to the red dummy switch.
Use a meter to find out which one is failing and replace it.
Old Sep 9, 2003 | 04:38 PM
ironrod's Avatar
Default oil light
Good call - You should test both. However, Its more than likey the water temperature sensor. The water proofing on that particular sensor is practically non-existant wearas the oil sensor is locked up pretty good.
Old Sep 9, 2003 | 05:22 PM
berksglh's Avatar
Default oil light
I just replaced my oil sender due to same light staying on. Sender was about 12 bucks. I blew off the conector good and slammed it full of dielectric grease to water proof it further. Never power washed my bike, garden hose only, and it still got in there. Doesnt take much to get by the rubber grommet.
Old Sep 9, 2003 | 09:31 PM
TrickyP's Avatar
Default oil light
thanks for the help guys I'll test both,, I talked to the dealer about it and its like talking to the wall I got my Baja from a boat dealer that sells sea doe's they have a bunch of DS's they can't get rid of because no one knows they sell ATV's I got a really good deal on it
Old Sep 9, 2003 | 10:43 PM
uthatch's Avatar
Default oil light
WOW, talk about a coincidence!!! I just posted the same exact problem. Thanks for the help!
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
