kodiac brake bleeding
Old Sep 9, 2003 | 11:52 PM
furby's Avatar
Default kodiac brake bleeding
How do you bleed the brakes on a kodiac. Just put a new brake and caliper on and can't get it bled
Old Sep 10, 2003 | 11:08 AM
Kodiac400's Avatar
Whether you bleeding disc or drum brakes there should be a little screw on the back. Sometimes there will be a little rubber cover on it. It looks like a greese nipple at a glance. There is only one and should be found on the top part of the caliper.
When you bleed the brakes................pump hand brake until they get hard to pull and hold brake lever while turning the bleed screw. This works best with 2 people. For a bit you might only have air coming out. Do this until only fluid comes out. Check master cylinder to make sure fluid level is still ok.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
