Squeaky front shocks on 450 es
Old Jun 2, 2000 | 09:36 AM
djlewis's Avatar
Has any one come up with a fix to stop the squeak on the front shocks on their 450 foreman ? I do not want to spend mega bucks on works shocks, Any one else having this prob? I have squirted oil and wd40 all over the shocks but the squeak continues.
Old Jun 2, 2000 | 10:39 AM
BigRed450's Avatar
I have the same problem and like you I have tried to oil them with no luck. This week I am going to take the front shocks off and grease the upper and lower bushings to see if that works. I believe the squeek is coming from the rubber shock bushing, so I'll try this first and see if it works.
Jeff
Old Jun 3, 2000 | 01:09 AM
muddiver's Avatar
man am i glad to hear that i am not the only one with this problem. i sprayed white lithuim grease inbetween the shock and plastic and tried to fill the shock with it . it is working better now. it was so bad that my wife could hear it on here bike while we were trail riding in the woods.
Old Jun 3, 2000 | 01:15 AM
ScooterTrash's Avatar
I had the same problem on my 2000 450 es with only 200 miles on it. Try spraying your shock bushings with Armor All. I do this each time I wash it and haven`t had a squeak yet. I`m sure I`ve seen a rubber lube at a auto parts store that will do the same thing but this works great.
Old Jun 3, 2000 | 09:29 AM
BigRed450's Avatar
Thanks
I'll try the Armor-all first. I use Armor-All all over the rest of the bike so I may as well try it on the shock bushings before I take them apart.
Jeff
Old Jun 3, 2000 | 08:00 PM
trailboss450's Avatar
25 Year Member
Thats what it is, the bushings. After a lot of mudding mine did it too. I pulled them out and put a light glaze of waterproof grease on last fall and they are not squeaking yet.
Old Jun 4, 2000 | 07:27 PM
BigRed450's Avatar
The Armor-All works great, no more squeeks. The only noise now is the compression of the shocks.
Jeff
Old Jun 5, 2000 | 12:53 AM
Rangercd's Avatar
I had a sqeak on my rancher front shocks also. I tried wd-40 and silicone spray nothing worked. I pulled the lower bolt that attaches the shock and put grease on the bolt then reinstalled. That was my squeak but the spray oils just couldn't get in there. While I was at it, I pulled the other bolts there and greased all of them also.
Bratman2
Aug 6, 2022 01:42 AM
07Redrider400
Jul 25, 2015 05:31 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
