HERES THE REAL 450R
Old Sep 11, 2003 | 12:21 PM
DaSandBomb's Avatar
Default HERES THE REAL 450R
Here it is, the 450R 350 pounds, 42mm carb, but its a kick start!
QUOTE: by honda.com
Engine Type: 450cc liquid-cooled single-cylinder four-stroke
Bore and Stroke: 94.0mm x 64.8mm
Compression Ratio: 10.5:1
Valve Train Unicam: four-valve
Carburetion: Keihin 42.0mm with throttle position sensor (TPS)
Ignition: CD with electronic advance
Starter: Forward kick
DRIVE TRAIN
Transmission Five-speed
Final Drive O-ring-sealed chain
CHASSIS, SUSPENSION, BRAKE & WHEELS
Front Suspension Independent double-wishbone with Showa shocks, featuring adjustable spring preload, rebound and compression damping; 8.4-inch travel
Rear Suspension Pro-Link with single Showa shock featuring adjustable spring preload, rebound and compression damping; 9.0-inch travel
Front Brakes Dual hydraulic 174.0mm discs with twin-piston calipers
Rear Brake Single hydraulic 190.0mm disc with single-piston caliper
Front Tires 22 x 7-10 knobby radial
Rear Tires 20 x 10-9 knobby radial
DIMENSIONS
Length 72.6 inches
Width 46.3 inches
Height 43.6 inches
Wheelbase 49.2 inches
Seat Height 32.6 inches
Ground Clearance 4.2 inches
Dry Weight 350.0 pounds
Fuel Capacity 3.2 gallons
OTHER
Age Recommendation For highly experienced riders 16 years of age and older.
Options Consult owner’s manual for optional HRC Racing Kit parts.
Available Colors Red
Model ID TRX450R
-kc
Old Sep 11, 2003 | 12:31 PM
stevendsm95gst's Avatar
why did honda go with a unicam?
Yesterday i was thinking that i may have bought a new quad early and should have waited to get the trx450. But now that i see the specs. Its the same weight as the yamaha but with kickstart. Unicam. Lower compression. I mean come on honda, its a big stepup from the 400ex but its not a stepup from whats already available.
I love my titanium valve dohc yamaha.
Old Sep 11, 2003 | 12:34 PM
1BigDSRider's Avatar
Finally, Honda has brought something new to the game. Now we just have to wait until January to see how it stacks up to the Yzf450. I hope Honda made this machine a beast.
Old Sep 11, 2003 | 12:45 PM
DEMag's Avatar
I'm sorry, but that thing is seriously fugly. Whoever designed those plastics should get a new profession.
Old Sep 11, 2003 | 12:47 PM
if you read the specs your question will be answered. Its definately not a beast.
Old Sep 11, 2003 | 12:51 PM
RoughRider01's Avatar
There are alot of questions that are unanswered by just reading the specs. Until one of us gets to ride it, we wont know how it sums up.
RoughRider01
Old Sep 11, 2003 | 01:18 PM
RoughRider01
very true. Anyone know the release date?
Old Sep 11, 2003 | 01:20 PM
imported_jmoney45's Avatar
They're saying January '04
Old Sep 11, 2003 | 03:46 PM
pudjumper's Avatar
I'm sure it will be a contender at the track with a little work.
JMiller
Old Sep 11, 2003 | 04:14 PM
Atkins450's Avatar
I think there are finally two new quads(yfz450, and the thr450r) that will finally rid the pro-production class of the trail oriented z400., and Honda signing Tim Farr, if you havent already noticed, is a Godsent. This now puts all of the other manufacturers under pressure to sign factory racers and will give top racers the money they deserve. And if manufacturers start sponsering racers, then they will start advertising their investment on TV and in the media, taking our sport to the next level![img]i/expressions/face-icon-small-happy.gif[/img]
