Help with 02' 400 Big Bear
Old Sep 11, 2003 | 06:19 PM
krazy3t's Avatar
Default Help with 02' 400 Big Bear
My ATV had been in storage the last 8 months. When I started it, it wouldn't idle and would back fire unless I had the choke on. Then it back fired and I can't get it to start at all now. Any ideas?
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 12, 2003 | 02:02 AM
witti's Avatar
Might have to clean the carb.
Old Sep 12, 2003 | 10:52 AM
krazy3t's Avatar
will try that...thanks
Old Oct 7, 2003 | 12:42 PM
just007's Avatar
Hello,
I have the same problem. I have a '01 Big Bear 400 4x4 and one day it was fine, and when I went to ride a couple days later it would not run. When I have the choke on it runs but back fires like crazy. I cleaned my carb twice and it still doesn't run right. I was wondering if you had any luck with yours. Thank you.
Justin
Old Oct 7, 2003 | 05:09 PM
ericstac's Avatar
This is the weirdest thing. I had mine in storage as well and pulled it out two weeks ago and had a hard time getting it to run. Finally it started so I left it on choke for about five minutes to run the engine then rode it for about an hour real lightly to break it in again and it would not run real well unless I put choke on. And even then it would backfire. I parked it and it hasn't started since. I was thinking i burned up the motor but after reading yalls post I'm thinking it might just need a good cleaning and a tune up. It always had problems running, it wouldn't idle when cold and when warm it would over rev. The damn yamaha shop said to let it break-in and now I'm having this problem. How much should I expect to pay the shop to clean and get it running right if it just needs adjustments. I can work on cars but I have never worked on one of these. If I knew where the screws are to adjust the carb I would attempt myself.
Old Oct 7, 2003 | 06:38 PM
shastadog's Avatar
These carb aren't that hard to clean out. If it ran right before you parked it shouldn't need adjusted. Just take the float bowl off the bottom and spray some carb cleaner thru the jets and needle valve this usually helps.
Old Oct 8, 2003 | 09:45 AM
krazy3t's Avatar
I tried cleaning it and it didn't help. Still won't start. Thought about taking it in to have it and having Yamaha do it. (But fear what they might charge)!!!
Old Oct 8, 2003 | 09:51 AM
rupezx's Avatar
had the same problem on a streetbike . try cleaning the gas tank too along with the carb. the gas gets all thick and goooye on the bottom of the tank.. hope it helps
Old Oct 8, 2003 | 11:00 AM
ericstac's Avatar
Well I'm going to change te oil, clean the carb and spark plug and see if this will do the trick on mine. I still think I will need to adjust the carb because it has always seemed to not run right since I bought it new. I think it is running to rich. Which way do I turn the adjustment screw to lean it out some?
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
