gearing
Old Sep 12, 2003 | 12:11 AM
scottsdalebomb's Avatar
Default gearing
I recently went to 22" Kenda Klaws, and will soon be ordering a set of 22" ITP Sandstars, Should I go a 14, or 15 tooth front sprocket, and if I go to a 14 will my chain still tighten far enough or will I need to remove links. Also it seems that I've read that there is interference with with some parts when installing the 14. Is this true.
Old Sep 12, 2003 | 08:39 AM
DCryder's Avatar
Default gearing
15/42 is the best way to go. Perfect for 22" tires.
Old Sep 12, 2003 | 09:49 AM
HillbillyDS's Avatar
Default gearing
The 14 will not work without taking out a link or two, already tried.
Old Sep 12, 2003 | 10:25 AM
buttfungus's Avatar
Default gearing
That's strange I've run a 14t on mine with the stock chain just fine?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 12, 2003 | 10:38 AM
SANDMAN430's Avatar
Default gearing
the 14 works just fine on a all stock machine, a few things to be aware of is the top engine mount that big bolt make sure the nut is on the shifter side just have to trust me on that other than that it's a good set up. oh that gearing will help you a lot for the sand i don't know about the dirt and mud.
Old Sep 12, 2003 | 06:50 PM
Default gearing
You guys got a 14 to fit with a 40 rear? I tried and ran out of chain adjustment, maybe I'll have to try again.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Sep 12, 2003 | 07:09 PM
buttfungus's Avatar
Default gearing
Yep! 14/40 works great on mine.
Old Sep 12, 2003 | 08:18 PM
TyreSpinner's Avatar
Default gearing
Yea try again... 14/40 and 22"s...stock chain and lovin' it [img]i/expressions/face-icon-small-smile.gif[/img]
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
