Predator Hot Seat Intake
Old Sep 12, 2003 | 06:11 AM
Funky's Avatar
Default Predator Hot Seat Intake
I was just wanting some thoughts about the Hot Seat High Flow Air Intake for the Predator for those who are rocking it. And what jet or jets and elavation. THANKS.
Old Sep 12, 2003 | 02:50 PM
POLRACER's Avatar
my brother and i both have it with the wB pipe. We run 55-57.5 pilot jet and 205-210 main jet with dynojet needle on 3rd clip down, breathes better than anything. my brother sold his air force kit after i had my hot seat set up dialed in and outrunning him. we run 3000-3500 ft elevation.
Old Sep 14, 2003 | 10:59 AM
jjwenzel's Avatar
Agree that this is the best mod. I replicated it and it runs so much stronger than the drop in K and N it is amazing. Note: I did a homemade kit and am still working the bugs out..ie..wish I would've just bought the kit. Now that I have the filter, outerwear ect I don't want to spend another 200. I made an adapter but it allows to much movement so the intake tube keeps coming off. It only comes off after slamming through a woops section but since I MX I need to fix. I'll just have to secure the adapter plate better.
Old Sep 17, 2003 | 06:39 PM
propolaris's Avatar
my hs intake is on the way cant wait to see if there is an inprovment over clamp on. running 185 main 50 pilot right now.
Old Sep 17, 2003 | 10:02 PM
jcal's Avatar
what does the hot seat intake include? looked but i couldn't find it or maybe i did. does it have the clamp on k&n?
Old Sep 17, 2003 | 10:05 PM
Scotts88's Avatar
yeah..its hard to see from the pic..looks like a small billit peice that connects the boot to the filter. Supposed to have awsome results though!
Old Sep 17, 2003 | 11:02 PM
jcal's Avatar
so it is a clamp on filter?
Old Sep 17, 2003 | 11:09 PM
Scotts88's Avatar
Well kinda...i think you use yoru stock neck that goes from the carb to the airbox, but you use the alum adaptor to attach the K&N filter. SO its not directly clamped onto the carb. Heres the picture..
HSP pred kit..filter & adaptor
Old Sep 18, 2003 | 12:41 PM
propolaris's Avatar
now i have a clamp on k&n off the carb and it works good but thers allways room for improvment. if the kit is no more than a clamp on i will send it back. but i have heard good things about it. If it is a good set up im going to order a high compression piston from hpd. ithink that will be enough for the kind of riding i do.
Old Sep 19, 2003 | 03:48 AM
Funky's Avatar
Does anyone know if you can leave the bottum of the airbox on with the Hot Seat Intake for extra protecton from mud and water. THANKS
