Predator Hot Seat Intake
Old Sep 19, 2003 | 01:30 PM
POLRACER's Avatar
Default Predator Hot Seat Intake
yes, you can leave the bottom of the air box on. i did , and all works well and fits well. Plus it comes with a K&N crankcase filter and outerwear (waterproof) for both filters.
Old Sep 19, 2003 | 07:49 PM
propolaris's Avatar
well i got my intake kit on and i like it better than my air force kit power wise really cant tell yet will go racing this week end to see if i can still beat my buddys raptor. i could easly beat him with the clamp on. may have to do some jetting dont no yet.
Old Sep 19, 2003 | 11:59 PM
Funky's Avatar
Just orderd the kit today after thinking about it for a while. 200 bones is alot for a intake kit, but I think from some studying and talking to some poeple which know alot this kit is the best. I had the SBS kit which put out some great power, but I just could not trust the cut out after the filter and it took to much maintance to keep clean. If anyone has any ideas of what jetting I should run it whould really help , I would like to get the jetting right the first time if possiable because the State closed down my riding-testing area that was just out side of town. I'm running the W/B Pure Polaris pipe with 8 disc and spark aarester. And I have a 55 pilot with my spring cut. THANKS
Old Sep 20, 2003 | 02:48 PM
jjwenzel's Avatar
I am running a 200 main and the spark plug was a medium brown. I did have to lift the needle to the 4th clip to get it to respond immediately when I hit the throttle. I think it gets so much air when you open the throttle it actually gets lean right away since there is no accelerator pump. I also have a 50 pilot. When I let off the throttle it gave a rich backfire but turning in the fuel screw eliminated most of this. Don't know if it is perfect yet but it is strong enough that I went to a 15/37 sprocket combo on my 18" tires. I like how it can pull strong in 2nd and 3rd and running tall gears reduces...shifting.
Old Sep 21, 2003 | 12:35 AM
  #15
propolaris's Avatar
im running 200 main seems to run best at this setting. no back fireing at all.
Old Sep 21, 2003 | 08:48 PM
  #16
propolaris's Avatar
well not impressed so far with hs intake kit need to do more jetting i guess. cuz the clamp on that i have is better so far. and makes more power.
Old Sep 22, 2003 | 08:22 PM
  #17
propolaris's Avatar
any body want to buy a high flow intake. take 140.00 new.
Old Sep 22, 2003 | 08:38 PM
  #18
jcal's Avatar
why don't you like it? was considering it but now may reconsider
Old Sep 23, 2003 | 01:18 PM
  #19
propolaris's Avatar
maybe you will have better luck than i im having. i would say its not worth 200.00 just my opinion. i went back with my clamp on. i think its getting to much air. maybe ill try bigger than 200 main later on little disgusted right now.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
