AC 250/300 LIFT
Old Sep 15, 2003 | 06:44 PM
Smoke's Avatar
Default AC 250/300 LIFT
Hey guys, just wondering if any of you out there have either personally owned or ridden the 250/300 with a lift kit. I am looking at the moose lift kit, does anyone have opinions on either this particular kit or lift kits in general? I have seen the 400/500s with lifts the look a little stretched out to me. If you know anything about the 250/300 AC series you know these machines are both underpowered and needs more ground clearance. If I can work on these two issues I will be much happier. Any pics or advice is much appreciated.
Old Sep 16, 2003 | 07:10 AM
RACERJIM's Avatar
I have a 02 300 with there lift and 28" 589 tires. High range 5th gear is useless. But it still runs about 40-42 mph. I just run it in mid range, 5th mid has the same power as 4th high an like I said she goes 40, but not fast around corners, it a little top heavy. I use this bike in the muddy season an trail ride in low range. It looks awsome with the lift, 589s, and also have lime green 250 plastic on it. I have 1000 miles on it and haven't broken a thing.
Old Sep 16, 2003 | 10:23 AM
Cancat's Avatar
I have a 250, I put the lift in, and 1" bigger tires all around, it works great...would do it again on a new one.
Old Sep 16, 2003 | 11:44 AM
Smoke's Avatar
Thanks for the replies guys!! I was on my second skid plate and I finally made my own out of diamond plate, using the old as a template. Anyway does this lift help against rocks? Help in deep rutted mud holes? Does it hurt you while hill climbing? Any pictures? Thanks again guys, I think I am gonna order a lift kit. Are you guys running the moose lift kits, or is there a better one out there?
Old Sep 17, 2003 | 10:24 AM
Cancat's Avatar
I used thw Quadrax Kit from Motovan.com catalogue (Canadian). It was less than $100 canadian...installed in minutes, and after a quick front end alignment I was back on the trail. It fit perfect...no surprises, and it helped my bike out a lot!!!
Old Oct 15, 2003 | 11:56 AM
memento's Avatar
What about putting some big washers or a rubber donut in the suspension spring? I don't want to pay the $100 for a "real" lift kit, but I would thing that this would certainely help. I'm not looking for huge lift, but just a little would keep my plow push frame from scraping.
Old Oct 15, 2003 | 02:21 PM
Cancat's Avatar
You can use Spring Spacers, but you will gain next to nothing, I would still reccomend the lift kit.
Old Oct 15, 2003 | 06:08 PM
memento's Avatar
Can you explain that a bit please. On my quad, when I put the plow on it and lift the plow, my front suspension drops considerably. I don't have a problem when the plow is down. So the way I see it, if I stiffen the suspension by adding spacers, I will not drop as low when I lift the plow. I'm trying to avoid spending $75 or so for the lift kit because I blew a wad of cash on the plow. Bigger tires are out of the question for this winter, too much $$$.
Old Oct 16, 2003 | 09:37 AM
Cancat's Avatar
Yes it will help your front end not drop when the plow is up, thought you were looking for an all round solution, for trails etc. I would expect that stiffer ride would make the quad harder to ride and less pleasant on the trails.
This is just my opinion, to each his own.
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
