oil cooler
Old Sep 16, 2003 | 11:39 PM
ypman's Avatar
Default oil cooler
I am debating putting an oil cooler on my warrior since I have it all apart. Does it really make a difference or is it more in your head.. I was also wondering if you could use the oil cooler from a wolverine so as not to have to drill and tap the clutch cover?
Any suggestions greatly appreciated.
Thanks
ypman
Old Sep 16, 2003 | 11:59 PM
Crotts's Avatar
Default oil cooler
The cooled oil goes to your head when you use the one that goes into the clutch cover and that is were you need it. I don't know how the one for the wolverine works or if it works for a warrior.
Old Sep 17, 2003 | 12:11 AM
ypman's Avatar
Default oil cooler
where exactly do you tap in the fittings?
Old Sep 17, 2003 | 12:51 AM
Crotts's Avatar
Default oil cooler
There is a oil galley on the inside of the clutch cover that you drill into and then use jb weld to block off between the two holes and then the oil pump pulles the oil through the cooler. It isn't really hard to do you just got to take your time
Old Sep 17, 2003 | 01:10 AM
blinddog's Avatar
Default oil cooler
has anyone tried an inline cooler?
Old Sep 17, 2003 | 06:12 AM
Kiwi_Craig's Avatar
Default oil cooler
see my web site for options............
Kiwi
Old Sep 17, 2003 | 12:52 PM
JakalWarrior's Avatar
Default oil cooler
The OEM one from a kodiac or whatever costs a ton just because its oem crap.
Old Sep 17, 2003 | 10:32 PM
ypman's Avatar
Default oil cooler
yea I put out a search to a bunch of online salvage yards looking for the cover off of one of the early big bear or kodiak. Is the wolverine part exactly like the big bear part?
Thanks
ypman
STLyamwar
Jul 25, 2020 04:44 AM
ronnierhino06
Nov 9, 2015 12:56 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
blessedn09
Aug 9, 2015 03:07 AM
metal249
Jul 24, 2015 01:00 PM
