Cold start problems with Grizz
Here are a few things you can check for, but if it were my guess I would start with the plug/ wire then go to the fuel/ carb. Post back with progress/ questions.
STARTING FAILURE/HARD STARTING
FUEL SYSTEM
Fuel tank
Empty
Clogged fuel filter
Clogged fuel strainer
Clogged fuel breather hose
Deteriorated or contaminated fuel
Fuel ****
Clogged fuel hose
ELECTRICAL SYSTEM
Spark plug
Improper plug gap
Worn electrodes
Wire between terminals broken
Improper heat range
Faulty spark plug cap
Ignition coil
Broken or shorted primary/secondary
Faulty spark plug lead
Broken body
CDI system
Faulty CDI unit
Faulty pickup coil
Faulty charging/rotor rotation direction coil
Broken woodruff key
Carburetor
Clogged pilot jet
Clogged pilot air passage
Sucked-in air
Deformed float
Worn needle valve
Improperly sealed valve seat
Improperly adjusted fuel level
Improperly set pilot jet
Clogged starter jet
Starter plunger malfunction
Air filter
Clogged air filter element
Switches and wiring
Faulty main switch
Faulty engine stop switch
Broken or shorted wiring
Faulty gear position switch
Faulty start switch
Faulty rear brake switch
Starter motor
Faulty starter motor
Faulty starter relay
Faulty starter clutch
FUEL SYSTEM
Fuel tank
Empty
Clogged fuel filter
Fuel ****
Clogged fuel hose
ELECTRICAL SYSTEM
Spark plug
Improper plug gap
Worn electrodes
Improper heat range
Ignition coil
Broken body
CDI system
Faulty CDI unit
Faulty pickup coil
Broken woodruff key
Carburetor
Clogged pilot jet
Sucked-in air
Deformed float
Worn needle valve
Clogged starter jet
Air filter
Switches and wiring
Faulty main switch
Faulty start switch
Starter motor
My friend had that problem on his raptor. He had to flood it to get it started. We tried a plug, and messed with the carbs. Then decided to check the valve adj. 4 out of the 5 were out of adj. we adjusted them and put it back togather and it runs great.
I would definetly start with the plug first though.
Big600twin
Jun 10, 2015 03:01 PM
