Cold start problems with Grizz
Old Sep 21, 2003 | 02:43 AM
Danzig's Avatar
Default Cold start problems with Grizz
Friend of mine has problems starting his '03 Grizz when it is cold. Any advice from other owners would be appreciated.
Thanks
Old Sep 29, 2003 | 01:14 PM
Vakero's Avatar
Here are a few things you can check for, but if it were my guess I would start with the plug/ wire then go to the fuel/ carb. Post back with progress/ questions.
STARTING FAILURE/HARD STARTING
FUEL SYSTEM
Fuel tank
 Empty
 Clogged fuel filter
 Clogged fuel strainer
 Clogged fuel breather hose
 Deteriorated or contaminated fuel
Fuel ****
 Clogged fuel hose
ELECTRICAL SYSTEM
Spark plug
 Improper plug gap
 Worn electrodes
 Wire between terminals broken
 Improper heat range
 Faulty spark plug cap
Ignition coil
 Broken or shorted primary/secondary
 Faulty spark plug lead
 Broken body
CDI system
 Faulty CDI unit
 Faulty pickup coil
 Faulty charging/rotor rotation direction coil
 Broken woodruff key
Carburetor
 Clogged pilot jet
 Clogged pilot air passage
 Sucked-in air
 Deformed float
 Worn needle valve
 Improperly sealed valve seat
 Improperly adjusted fuel level
 Improperly set pilot jet
 Clogged starter jet
 Starter plunger malfunction
Air filter
 Clogged air filter element
Switches and wiring
 Faulty main switch
 Faulty engine stop switch
 Broken or shorted wiring
 Faulty gear position switch
 Faulty start switch
 Faulty rear brake switch
Starter motor
 Faulty starter motor
 Faulty starter relay
 Faulty starter clutch
Old Sep 30, 2003 | 12:22 PM
Kraw's Avatar
mine had trouble starting, turned out to be the plug
Old Sep 30, 2003 | 12:49 PM
warrior007's Avatar
change the plug and since its colder out now, you may be lean. Richen it up a little on the idle ckt, I like a 1/2 turn out on the fuel screw.
Old Oct 1, 2003 | 02:30 AM
witti's Avatar
My friend had that problem on his raptor. He had to flood it to get it started. We tried a plug, and messed with the carbs. Then decided to check the valve adj. 4 out of the 5 were out of adj. we adjusted them and put it back togather and it runs great.
I would definetly start with the plug first though.
Old Oct 1, 2003 | 09:48 PM
Danzig's Avatar
Thanks everyone,
Adjusted the valves. We will see how much that helps when we get colder weather.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
garyt1975
Jun 5, 2015 08:53 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
