y cant i do long wheelies on my mojave
Old Sep 21, 2003 | 09:21 PM
mojaveman342's Avatar
Default y cant i do long wheelies on my mojave
y cant i do wheelies? i can get it up but cant find balenec point y? and i cant kept it going
Old Sep 21, 2003 | 10:37 PM
kybabyn's Avatar
hay man i have a 93 mojave and the only way i can get the front up really high is with one foot on the grab barand the other on the peg to shift. i find it has a really easy balance point but i cant get the front up higher than a foot with bothe feet on the pegs. the balance point is really high though like it likes to be almost straight up. i can shift to 3 but i drop it then. an easy way to find the balance point is put one knee on the seat and foot in the grab bar and the other foot trailing behind so when your up you can push back forward if your to far. just keep bliping the throttle.
Old Sep 22, 2003 | 02:19 AM
clover's Avatar
hey a good way to find the balance point is to find you a hump or something a give it gas up the hill a just try to find the balance and if you have a good grassy area do it there a don't be afraid of falling off,this is how if find it on my lakota is in a grassy area i fall off alot,but i can ride wheelie a good 30-40ft.So just try to do this and keep practicing and it will come to you.
Old Sep 22, 2003 | 11:00 AM
mojavekid13's Avatar
I can wheelie my mojave for a mile sitting on the seat in 5th gear! Maby longer dont know road ended!
Old Sep 22, 2003 | 04:42 PM
if im going to fall how shuold i fall so i dont get hure or anything esle
Old Sep 22, 2003 | 09:56 PM
josh's Avatar
i can get the mojave up and im only 114 pounds you start off in hammer first then shift into second and kinda slip the clutch and shell go up once you get it up they balance awesome and then you can start shifting with the clutch
Old Sep 23, 2003 | 04:36 PM
y can i do a long wheelie on my freind 250z better than i can do on my mojave
Old Sep 23, 2003 | 07:53 PM
mojave03's Avatar
pull in the clutch and shift into 1st or 2nd and give it like 3/4 throttle and just pop it
Old Sep 23, 2003 | 11:02 PM
kruzoffman's Avatar
hey man i have a lt250r and i can wheelie that thing great. i also had a 3ooex and that thing is the best wheelie merchine i had. i friend has a banshee and he can wheelie that thing for ever. to do wheelies siting down , you have to put it in first, and just idle in first when your idling in first, push down on the footpegs and pull back on the bars wile giving it gas when the front end comes up give it gas. also before you even try to attempt this make sure you have your foot on the brake.good luck
Old Sep 24, 2003 | 12:49 AM
kybabyn's Avatar
ya but poping the clutch while reving that high is bad. keep doing that and in a year you will have nothing left for plates.
