warrior hit rev limiter
Old Sep 22, 2003 | 10:02 AM
warriorracer15's Avatar
Default warrior hit rev limiter
i recently had my warrior rebuilt with a thompy kit. it consists of a low range web cam and a wiseco piston. i have a k@n air filter and a white bros. r4 pipe. can anyone help me.
i have had it rejetted.
Old Sep 22, 2003 | 10:07 AM
Yamaha660R's Avatar
what's the problem...if your hitting the limiter gear up the front sprocket one or two teeth.
Old Sep 22, 2003 | 10:12 AM
my problem isnt in the gear its in the electrical components. i dont think they make a aftermarket rev box for a warrior.
Old Sep 22, 2003 | 12:11 PM
warrior620's Avatar
Hate to burst your bubble, but warriors do not have a rev limiter. Do you still have your parking brake attatched? That could be causing your problem... what excactly is it doing??
Mike
Old Sep 22, 2003 | 01:15 PM
Mr45auto's Avatar
Warriors have notoriously weak valve springs, you'll float your valves long before you over rev the machine. It will sound like a rev limiter as it will pop and miss until the valves operate properly again. Replace your valve springs with new ones from webcam or another source. It may also be your carb causing the problem. I chased a similar problem around for a long time with my Warrior.
Old Sep 23, 2003 | 09:35 AM
i have had the bike rejetted and the valves are all brand new.
Old Sep 23, 2003 | 11:03 PM
Mr45auto's Avatar
Rejetting could be the issue entirely, if you're jetted too fat it will blubber when you get it revved out. It will sound like it's being cut out electrically.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
