warrior hit rev limiter
i recently had my warrior rebuilt with a thompy kit. it consists of a low range web cam and a wiseco piston. i have a k@n air filter and a white bros. r4 pipe. can anyone help me.
i have had it rejetted.
Warriors have notoriously weak valve springs, you'll float your valves long before you over rev the machine. It will sound like a rev limiter as it will pop and miss until the valves operate properly again. Replace your valve springs with new ones from webcam or another source. It may also be your carb causing the problem. I chased a similar problem around for a long time with my Warrior.
Steeldon
Sep 9, 2015 09:38 AM
