Scrambler "boging" on hills (carb issue?)
Old Jun 5, 2000 | 03:56 AM
johndjmix's Avatar
I didnt seem to have this problem until after I added a pipe and up-jeted. When the bike was on a slope for a few secs I would not be able to give it more that 1/4 throttle, so I couldnt even move. And no, it wasnt like a running out of gas....it was running really really really rich when on the hill. When it wasnt on a hill it ran mint. I took off that little "one-way" valve on the carb and it seems to be fine now, but im not sure if that was the problem.
On my 400ex when I routed the "float bowl overflow" hose up, it choked rich on hills....I later found out that this line needs to let out fuel when on steep slopes...so maybe the one-way valve on the scrambler was stuck shut?
Has this scrambler richness on hills happened to anyone else?
Check out my name in this months ATV Sport! They talked about my winch on the scrambler in the 4x4 race quad section!
John
Old Jun 5, 2000 | 11:26 PM
ryanmat's Avatar
My scrambler had a similar problem like that. The engine would rev up like normal and it just wouldn't hardly make it up the ramps onto the back of the truck. The problem was that the clutch buttons broke and the clutch just spun and I could hardly move. I don't know if that is the same case with you or not, but is an idea. I fixed it myself and it only cost me $4.50.
Another idea is if it feels like that something is holding you back, like it just isn't using all of its power, it could be the air flow. Check your filter and make sure that it is clean and take you pilot jet out and see if it is the right size and make sure that it is clean. If you have any questions, e-mail me at ryan_mathies@hotmail.com
Old Jun 5, 2000 | 11:27 PM
ryanmat's Avatar
Old Jun 6, 2000 | 06:46 AM
johndjmix's Avatar
Definatly was'nt a clutch issue...Ive had enough machines to know when a motor is getting too much fuel and is choking on it.....
Good to know about the clutch buttons though.
chinkapin
Jul 14, 2016 06:58 AM
JBibb
Jul 4, 2015 10:16 AM
Dabears1983
Jun 16, 2015 12:17 PM
robj
Jun 15, 2015 08:45 PM
