Baja X Skid Plate, Pro Armor or AC Racing
Old Sep 22, 2003 | 08:41 PM
dhenricks's Avatar
Default Baja X Skid Plate, Pro Armor or AC Racing
It looks like the skid on my 2002 will fit on my 2004 Baja X. I bought the Bombardier metal skid and you have to remove the axle to put it on. Has anybody tried to fit the Pro Armor, DG, or AC Racing Skid yet.
Old Sep 23, 2003 | 01:04 AM
kehale's Avatar
you may be the first member WITH an X. lol
I'm sure someone will chime in sooner or later.
That aluminum swingarm looks sweet!
-T
Old Sep 23, 2003 | 04:01 AM
BlackHawk's Avatar
I heard that the Pro Armor skid will not fit. I don't know if it is something minor that can be changed or not.
Old Sep 24, 2003 | 11:06 PM
dhenricks's Avatar
I bought a pro armor and am going to give it a try. I bought the Bombarder swing arm skid plate and took it back. To small and to light. You have to remove the axle and brake disk and chain sprocket to put it on. To much work. It also does not cover very much of the swing arm or chain. The PRM and ProArmor cover 3 times more.
Old Sep 24, 2003 | 11:12 PM
lilnotts's Avatar
i hope it works for ya, i know i love my pro armor one, really thick and takes a beatin,
Old Sep 25, 2003 | 04:16 PM
BigJon's Avatar
I have all ofthe pro armor and have beaten it on several rocks.
It holds up really well.
Old Sep 26, 2003 | 05:02 AM
fourlix's Avatar
Little trick here for installing the rear skidplate. Instead of removing the axle/sprocket etc. just cut the bolts that hold the skid, which you can't get off without cutting or dissassembling everything. It is easy to put back together with the new bolts going in the other way. Turns a 3 hour job into one hour....
Old Sep 26, 2003 | 01:32 PM
BlackHawk's Avatar
fourlix,
I did that on my 2001 for my DG Baja skid it - cutting the bolts worked well. However I like the setup Pro Armor has even better - you don't ever remove the stock plastic guards, and you only unscrew bolts that are accessible. The bolts that cannot be removed have been slotted on the Pro Armor skid so installarion of the Pro Armor skid is like ten minutes!
Old Sep 26, 2003 | 05:33 PM
BigJon's Avatar
Yeah thats the nice thing is you dont have to remove the stock and its like having a steel tank for protection.
Remeber to check the nuts every once in a while though.
Old Sep 26, 2003 | 08:37 PM
BlackHawk's Avatar
BigJon,
You are 1000% right about checking the nuts. Evidentally I didn't tighten mine enough and last trip I heard a 'click click click' noise. I finally figured out it was the bolt that holds the skid on had backed out enough to hit the mounting bolts for the rear sprocket. I tightened up both bolts (both sides were loose in the back and everything was good. Needless to say I was careful to ensure they were much, much tighter this time!
Robinhood
Dec 26, 2015 10:28 AM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
