Installation help(durablue)
Old Sep 26, 2003 | 07:48 PM
polarisisthebest's Avatar
Default Installation help(durablue)
I just got my axle in and was wanting to make sure i understand this right. It came with 4 little spacers.Am i suppose to put these in back of the hub to make it wider? Also it came with another little ring what do i do with this? Thanks for any help.
Old Sep 26, 2003 | 07:57 PM
RacerRob's Avatar
I'm gonna save you a ton of headaches....lol. The 4 rings are spacers to widen the track...they go behind the hub, just like you said. The extra ring is for BANSHEE applications ONLY....it took me hours to figure this out....I finally read the directions...LOL....[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
Old Sep 26, 2003 | 08:18 PM
Thanks, i couldnt figure out what that extra ring was for either. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 26, 2003 | 09:06 PM
Well im still confused i put the axle on with out that little ring but when i put it on there was some play in it still , so what do you suggest now.
Old Sep 26, 2003 | 11:00 PM
RacerRob's Avatar
What should happen is once you get the "O" rings seated in their grooves(one on each side of carrier), just tighten the axle nut and it will push the inner nut outwards and tighten up. I installed 2 Durablue axles on our Raptors and it worked fine....[img]i/expressions/face-icon-small-cool.gif[/img]
Old Sep 27, 2003 | 02:29 PM
Thanks RacerRob, I finally got. The problem was before I had the inner nut pushing inside but it worked when i flipped it around to push outside. Also I tried it out and I really like it I can now turn really sharp going fast , it feels much more stable than before.
Old Sep 27, 2003 | 06:26 PM
RacerRob's Avatar
Glad you got it figured out. Just make sure you check it every once in a while, if it loosens, try covering the threads with Lock-Tite. Mine loosened up after a couple hard rides and after the Lock-Tite, it hasn't budged.....[img]i/expressions/face-icon-small-cool.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
