Installation help(durablue)
I just got my axle in and was wanting to make sure i understand this right. It came with 4 little spacers.Am i suppose to put these in back of the hub to make it wider? Also it came with another little ring what do i do with this? Thanks for any help.
I'm gonna save you a ton of headaches....lol. The 4 rings are spacers to widen the track...they go behind the hub, just like you said. The extra ring is for BANSHEE applications ONLY....it took me hours to figure this out....I finally read the directions...LOL....[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
What should happen is once you get the "O" rings seated in their grooves(one on each side of carrier), just tighten the axle nut and it will push the inner nut outwards and tighten up. I installed 2 Durablue axles on our Raptors and it worked fine....[img]i/expressions/face-icon-small-cool.gif[/img]
Thanks RacerRob, I finally got. The problem was before I had the inner nut pushing inside but it worked when i flipped it around to push outside. Also I tried it out and I really like it I can now turn really sharp going fast , it feels much more stable than before.
Glad you got it figured out. Just make sure you check it every once in a while, if it loosens, try covering the threads with Lock-Tite. Mine loosened up after a couple hard rides and after the Lock-Tite, it hasn't budged.....[img]i/expressions/face-icon-small-cool.gif[/img]
jrooker6
Apr 23, 2016 07:36 PM
