rpms go up when steering wheel is turned
Old Sep 27, 2003 | 02:37 PM
rtellor's Avatar
Default rpms go up when steering wheel is turned
i recently got my polaris atp serviced and they changed the idle speed around some, now when i turn the wheel, the cord tightens and the engine gets more gas. in neutral the rpms will just go up but if its in gear it slowly rolls around the yard. is there anything i can do besides take it back to the shop?
Old Sep 27, 2003 | 02:42 PM
Hozed's Avatar
i wouldnt do anything to it my self.. take it back to the shop and let them do it. it would be the smart thing.
Old Sep 27, 2003 | 03:13 PM
skidkid's Avatar
rtellor,
If the idle is changing when you turn the handle bars from left to right you need to adjust your throttle cable. Its just down the cable from the throttle assembly. Pull back the rubber boots and adjust it, then turn your handle bars and make sure that there is no change in the rpm at idle.
Old Sep 27, 2003 | 03:19 PM
fishslab's Avatar
Try to make sure the throttle cable is free all the way to the carb. If they pulled the tank, which you have to do just to change the spark plug, they may have routed it wrong. Play with it a little as you turn the bars to find the right spot for the cable to rest.
Old Sep 27, 2003 | 03:31 PM
RacinJason's Avatar
Take it back...it sound like the cable is routed wrong
Old Sep 27, 2003 | 07:52 PM
trailrider500's Avatar
Like thay said its routed wrong. The same thing happend to my scrammy when I checked my plug, when I put it back together I routed the cabel rong just a slight miss rought will cause that problem. You could take the plastic off and check the routing but I would take it back make them fix it!!
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
ranvette
Jul 12, 2015 06:34 AM
Scottma518
Jul 10, 2015 12:42 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
