jet kit questions
Old Sep 28, 2003 | 09:55 PM
chadscrambler's Avatar
Default jet kit questions
will jetting my ds make it harder to start?? can i do it myself or is there alot of adjusting that has to be done ?? and will any aftermarket muffler help it or do you need to match it with a muffler.. what kind of results will I see from this.. it is all stock now and I am wanting to win the grass drags that we are having here in a month.. help me out guys :-)
Old Sep 29, 2003 | 01:09 AM
marrtoo's Avatar
Your best bet is to do a search on this forum for jetting or carb and you will get all the answers you will need.
Old Sep 29, 2003 | 01:42 AM
RoughRider01's Avatar
When i jetted mine it actually started better, I think just because i played with the air/fuel screw. The pilot jet helps with starting, but i dont think many jet kits have that type of jet.. i think you have to order that one seperate (someone correct me if im wrong).
You can do it yourself. I had no clue how to adjust my carb at first but i didnt have a problem with it. Just take your time, plus theres alot of ppl on here that can help you if you need it. ( there lots of recent posts about how to jet on here too)
You dont really need to match your jettting to your pipe, well sorta. Some pipes flow better then others, just play around with the jets and youll find the right one.
I think the DS is pretty choked up stock. Pipe, filter and jets really help alot.
You may wanna consider a higher CDI if you want to get more REV's since youll be dragging. The stock rev limiter works for for trail riding. I only bump it when im racing someone which i dont do often.
Im not a pro or anything when it come to tuning the stock carb, but i can get you on the right track.. PM me if you need more help when it comes time to rejet.
RoughRider01
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
