what is the easiest way to ajust the stock front suspension on a 2002 warrior?
Old Sep 28, 2003 | 10:41 PM
VirginRider's Avatar
Default what is the easiest way to ajust the stock front suspension on a 2002 warrior?
title says it all, my suspension is at the lowest setting and it is killing me, whats the best way to adjust the springs it seems that I need some sort of tool, but is there anyway of using simple household basic tools?
Old Sep 29, 2003 | 09:42 PM
roosthrower's Avatar
a large pair of pliers can do the job.
Old Sep 29, 2003 | 10:15 PM
so just get the pliers on there and start twisting? no reason to try to compress the spring?
Old Sep 29, 2003 | 10:42 PM
whatwasthat's Avatar
i suggest getting someone heavy to stand on the bumper, while you, with rope or strong zip ties or something similar, hold the shocks in place to the top of the shock supports, that way, when you go to adjust the compression, it wont have as much pressure holding you back.
Old Sep 29, 2003 | 10:44 PM
just twist. at the bottom of the shock is the preload adjustment.
Reactant
Mar 30, 2022 02:08 AM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
Jkfx400P
Jul 6, 2015 10:04 AM
