When to re-jet?
Old Sep 29, 2003 | 04:30 PM
98cobra's Avatar
Default When to re-jet?
How can you tell when you need to rejet? I'm thinking of opening up my air box but not sure how to tell if I will need to rejet and where do I get jets from? I have a vforce if that will helps.
Old Sep 29, 2003 | 04:49 PM
trailburner's Avatar
run your machine 'till it is warm, remove plugs and check for color. If they are wite, it is lean. If they are black, you are to rich. You want them to be kind of a tan color. You can find jets at your dealer's or online at rockymountainatv.com.
Old Sep 29, 2003 | 05:28 PM
98cobra's Avatar
trailburneris it better to be on the lean side or the rich side?
Old Sep 29, 2003 | 05:34 PM
KevinM's Avatar
Sudco is the cheapest place I've seen for jets. 4-strokes are more tolerant of a lean condition, but it never hurts to be just a little rich. Check your plugs anytime you change something on the motor.
Old Sep 29, 2003 | 10:11 PM
Wires's Avatar
98 cobra,
It's always better to be rich than lean. Too rich, and you lose power, but too lean and she'll knock, which can lead to piston damage.
Old Sep 29, 2003 | 10:18 PM
iamnothing's Avatar
I don't know what they're doing at Kawasaki, but I was told buy a mechanic from this shop in PA that he opened the airbox, installed a K&N w/outwears, and a full HMF dual system without re-jetting and was only running slightly lean. So don't be afraid to try it, but as stated, make sure you check the plugs when you're done.
JohnnySplat
Aug 6, 2015 12:07 PM
SMW
May 18, 2001 04:40 PM
ssimons
May 20, 2000 10:08 AM
tomuchfun
Mar 16, 2000 06:20 PM
