TEST YOUR ATV SKILLS
Old Sep 30, 2003 | 08:38 PM
atvantonio's Avatar
Default TEST YOUR ATV SKILLS
MY 2000 MOJAVE STARTS OK AND RUNS GRATE....BUT WHEN I TURN THE GAS ON THE OVERFLOW PISSES LIKE CRAZY THIS REALLY SUCKS.GAS SPILLS EVERYWHERE PLUS IT EMPTYS MY TANK.......HELP ME PLEASE.....EVERY TIME I ASK A QUESTION NO ONE KNOWS ANYTHING OR JUST WINT ANSWER.....HELP ME....I JUST WANNA RID MY ATV I JUST BOUGHT IT SEPTEMBER 28 I NEED TO RIDE I WORKED MY *** OFF 4 THIS THINS HELP ME PLEASE.....THANKS
Old Sep 30, 2003 | 09:22 PM
josh's Avatar
the float in the carburator could be stuck call a kawi dealer and find out
Old Sep 30, 2003 | 09:27 PM
atvantonio's Avatar
DO U THINK YHAT WOULD REQUIRE A REBUILT CARB OR IS IT SIMPLER THAN THAT???OH...AND THANKS
Old Sep 30, 2003 | 11:41 PM
Bigsaint's Avatar
The float in a carb needs adjustment from time to time. Get a factory service manual or take it to the dealer. Very easy to do though. If you have the ability to remove the carb you can adjust the float yourself.
Scott W.
Old Oct 1, 2003 | 10:17 AM
brownracing's Avatar
Take the bottom of your carb off and spray the float with carb cleaner and let it soak actually just spray everything if it looks gummed up.
But if you just bought it I would tell the dealership you bought it from to take care of you.
Old Oct 1, 2003 | 01:27 PM
fartman's Avatar
couldnt it be the float drain open? its a screw down on the bottom of the float bowl. i know when i turn that screw it drains all the gas in the carb.
Old Oct 2, 2003 | 01:21 AM
KAWIMECH's Avatar
yes its usally the float is stuck open and the first thing i usally try is to peck on the bowl of the carb with the plastic end of a screwdriver to get the float working, if that dosent cure it then take the carb off and this can be done without removing the plastic and check the float height its usally about 20 mm from the bowl mating surface
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
