Was there an issue with RW CDI and starting?
Old Oct 1, 2003 | 12:14 AM
MudStud's Avatar
Default Was there an issue with RW CDI and starting?
I looked and can't find what I wanted.. Do I remember an issue with the CDI with an issue regarding charging or starting? I am just wondering now that I have the CDI and battery issues... I may be thinking about the 400ex I am not really sure.
Old Oct 1, 2003 | 02:41 AM
marrtoo's Avatar
I have the ron woods cdi and do not have either problem. I do not recall reading anything about it either.
Old Oct 1, 2003 | 09:01 AM
DCryder's Avatar
Seems like IRONROD had a little starting and idling problem with his after he installed the 14:1 piston. I haven't had a problem with mine at 12.5:1.
Old Oct 1, 2003 | 09:17 AM
Hightower's Avatar
yeah I've heard from several people that high compression ratios past 13:1 need retarded timing in the low rpms and the RW cdi is too advanced for them.
Old Oct 1, 2003 | 04:46 PM
ironrod's Avatar
MudStud,
Ok man, here the scoop. There have been no issues with the Ron Wood Racing CDI with regards to working with the 11.5:1 piston. Certainly nothing regarding charging. However, I did have an issue with my old Ron Wood Racing CDI working with the 14:1 piston. The timing is simply too advanced at idle to run that piston well at idle RPM. I tried it and found that, even with the choke on, the motor would simply dead ping at idle. That's kind of scary if you think about it. I don't know if other people had any problem with the same combination - I dont know of anybody with the same combination either. I do know there has been no changes in the power curve for the Ron Wood Racing CDI since its inception. I replaced mine Ron Wood Racing CDI with the Vortex and now it just purrs at idle. Its important to note that the power curve I chose on the vortex is the most advanced curve - and it still purrs at idle.
Curves that are too advanced on the top end tend to be detriment to running well at idle.
Old Oct 1, 2003 | 06:03 PM
MudStud's Avatar
Good, I am glade to hear it's all good. I was just making sure it was not my CDI that was causing my battery issues. I just bit the bullet and bought the PC545 dry cell. Thanks..
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
