cleaning air filter
Old Oct 2, 2003 | 08:55 PM
javex's Avatar
Default cleaning air filter
use gas or paint thinner? .. then wash with water and soap?
Old Oct 2, 2003 | 09:09 PM
RoughRider01's Avatar
for the stock one? dont have my manual with me but i know it says in there. i never liked the thought of using gas, it would be scary if some was left behind and you backfired through your carb
RoughRider01
Old Oct 2, 2003 | 09:19 PM
javex's Avatar
stock filter
Old Oct 2, 2003 | 09:20 PM
javex's Avatar
manual says to use a bombardier product...probally expensive..
Old Oct 2, 2003 | 10:18 PM
TyreSpinner's Avatar
I'd say use a good soap... Like Dawn or something...
I wouldn't put solvents or harsh chemicals on that... JMO
Old Oct 2, 2003 | 10:21 PM
DogS's Avatar
I use castrol super clean. you can get at wal-mart.
Old Oct 2, 2003 | 10:53 PM
PUSHINTHELIMIT's Avatar
I use a good degreaser (like 409) to clean my K&N filter. I use water to get the filter wet, spray on the degreaser and rub it in the filter a little, and rinse it off. I repeat the process untill the filter almost isn't red anymore. Then I let it sit in my house over night so it can dry, then the next mornning I oil it..... It's always a good idea to rinse the filter off FROM THE INSIDE of it with a hose.
Old Oct 3, 2003 | 07:21 AM
pads's Avatar
Isn't the stock filter paper with a thin removeable foam element or have they changed them on the '03? If they are foam, you can use gasoline, the problem with that is that it eats the material in the filter. Kerosene is an option because most over-the-counter cleaners use some form of mineral spirits. I'll have to look at the name again, but I purchased a water-based oil and solvent that will soon be marketed by Honda. It is easy to clean with just an additive to water and is easy to wash off your hands. It works great for my UNI.
If the stock filter is paper, when it gets dirty, you change it.
COFatboy
May 2, 2020 12:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
