sparkplug on 454
Old Oct 3, 2003 | 07:21 PM
Jockdawg's Avatar
Default sparkplug on 454
can anyone tell me where the sparkplug on a 1998 454 is? thanks in advance
Old Oct 3, 2003 | 08:34 PM
CatRider's Avatar
When you are sitting on the machine, the plug is on the left side, at the top of the engine. Remove the side plastic that runs between the front and rear fender. You can see where the plug wire connects to the top of the engine, but the plug is recessed. You have to pull the plug wire before the plug can be seen.
Old Oct 8, 2003 | 09:12 AM
Andy Bassham's Avatar
I think it uses the NGK CR8E plug, but a CR6E works better for it.
Old Oct 8, 2003 | 02:56 PM
TORK's Avatar
Use CR6E, Other plug fouls too easy, CR6E is recommended, Also change to foam filter instead of paper one if you have not already.
Old Oct 8, 2003 | 05:51 PM
Jockdawg's Avatar
what foam filter are you talking about?
Old Oct 8, 2003 | 08:38 PM
TORK's Avatar
Original filter was paper with foam pre-filter wrapped around it. A foam filter is available. Does away with paper filter. Paper worked good but we found harder to get cleaned. would cause plugs to foul easier.
STLyamwar
Jul 25, 2020 04:44 AM
freeman34
Jan 8, 2016 11:46 AM
mattcraig1
Aug 19, 2015 03:48 PM
cornermike
Jul 30, 2015 06:37 AM
97fourtrax300
Mar 11, 2003 06:11 PM
